Skip to product information
1 of 5
Aim Solo 2 GPS Track Day Racing Lap Timer
SKU: SOLO2-K1
£350.00
£350.00
The Most Precise & Easy Way To Get Lap Times
Upgrade your track day setup with one of the best motorsport lap timers in the industry — the Solo 2 GPS Lap Timer. Equipped with a 25 Hz GPS, built-in gyro, user-friendly interface and compatibility with session performance analysis software, the Solo 2 provides precise lap times and detailed telemetry for amateur and professional racers to optimise their performance and achieve their racing goals.
Solo 2 Key Features
Integrated GPS
Wi-Fi Connectivity
4GB Internal Memory
Extensive Track Database
Automatic Track Recognition
10 Configurable RGB LEDs
Graphical Display
3D Accelerations & Gyro
Multiple Race Modes: Speed, Times & Performance
Rechargeable Lithium Battery
Why Choose The Track Day Solo 2 GPS Lap Timer
The Track Day Solo 2 Lap Timer includes a high-precision 25 Hz GPS and receives data from GPS and GLONASS satellite constellations. This allows the Solo 2 Lap Timer to display instant speed, timing splits, live data and predictive lap times on its high-contrast display with an accuracy of two-hundredths of a second to help drivers improve their performance on the track.
The reliable predictive lap time function on the Solo 2 uses real time GPS data and a database of track layouts to estimate your current lap time, showing you in real time how your current lap compares to your best lap or a reference lap. The LEDs are also configurable to provide a visual indication of whether you are quicker or slower.
The Solo 2 also features a theoretical lap timing mode which pieces together your overall best sector times to provide an optimal lap time that could be achieved.
Advanced Display
The Solo 2 Lap Timer features a 238x99 pixel graphical display, ensuring excellent readability in various motorsport applications. The display also allows for 10 configurable RBG LEDs, up to 5 freely configurable display pages and 8 different backlight colours, which you can select to suit your preferences.
Accurate Lap Times
The Solo 2 Lap Timer features a 25 Hz GPS receiver and a 100 Hz 6-axis inertial platform. It calculates, shows and records lap times, sector times, position & vehicle speed and 3D acceleration & gyro.
The Solo 2 Lap Timer includes valuable information about the track. Thanks to the thousands of pre-loaded track maps worldwide, the lap timer automatically recognises your position on the track as soon as it's switched on. Once you start to drive, it automatically recognises the start line coordinates of the track and starts sampling lap times every time you go past.
Whether it's used for circuit racing or performance tests such as 0-60mph, the Solo 2 allows you to create a new temporary or permanent track layout too. Even if there is no track already, the device will create one for you.
Important: Import your track performance to Race Studio 3 Software to analyse racing lines, cornering speeds and braking points to improve your lap times.
Wi-Fi Connectivity
The Solo 2 has integrated Wi-Fi to allow you to conveniently transfer your data securely, straight from your car to your laptop/PC at the trackside. You can then review your racing data in more depth by importing it to our free Race Studio 3 software, which can be done from up to 50m away without the need for connectors and cables.
Aim Solo 2 Gyro Diagram
The inertial platform at 100 Hz gives the possibility to calculate roll, pitch and yaw. This provides detailed insights into your car's dynamics, including steering position analysis for understanding oversteer and understeer to help fine-tune your setup for optimal performance on the track.
With Race Studio 3, you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You can also manage the map of all your racing tracks and compare two laps by watching the video recorded by the SmartyCam HD camera.
Race Studio 3 also allows you to download and analyse all data recorded by your Solo 2 to your laptop/PC. With graphs, histograms and tables, you can study your lap and sector times to refine racing lines and braking points to enhance your racing performance.
Compatible Accessories
One of the reasons why the Solo 2 is regarded as one of the best track day lap timers in the motorsport industry is due to its lightweight and compact design. The Solo 2 can easily be mounted and connected to your dashboard or windshield with a range of compatible Aim Solo 2 accessories:
Solo 2 Key Features
Integrated GPS
Wi-Fi Connectivity
4GB Internal Memory
Graphical Display
Advanced Display
Accurate Lap Times
Wi-Fi Connectivity
Technical Specifications
Aim Solo 2 GPS Track Day Lap Timer
  • Display: Graphical
  • Display Pages: Up to 5 freely configurable
  • Backlight: 8 configurable RGB colours
  • Wi-Fi connection: Yes
  • GPS: 25 Hz
  • External power: 12 V
  • Connectors : 1 socket (binder) 712, 5 pins
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
solo2 pinout
What's In The Box
  • Solo 2 power cable with car lighter socket
  • Power cable with AC adapter
  • Aim Sticker
