    10 Button Wireless Steering Wheel Plate - AimShop.com
    RBI-WW-10
    Hurry, only 2 items left in stock!
    £790.00
    £790.00
    With the Motorsport steering wheel plate, racing is made faster, slicker and safer with push-button controls at your fingertips. We're combining minimum driver distraction with maximum ease of use to make you stand out on the track.
    CAN wireless system
    CR2 lithium battery
    2 12 position analogue inputs
    Bolt between the wheel & boss
    3-year guarantee
    8 push buttons
    Why Choose The 10 Button Wireless Steering Wheel Plate
    The ten wireless channel system allows you to have pushbutton controls at your fingertips whether you have a detachable steering wheel or would like to avoid the need for an unreliable coiled wire connection from your steering wheel to the dashboard.
    Wireless Connection
    The system uses a wireless (RF) connection between the wheel plate transmitter and the CAN receiver. The compact receiver is neatly installed behind the dashboard and attached to an Aim CAN device directly using the binder harness.
    Compatibility
    The steering wheel plate is lightweight and integrates with most CAN devices, including dashboards, ECUs, PDUs and data loggers, and has been tested to withstand the harshest EMI generated within your vehicle.
    It has been carefully designed for most standard bolt patterns on 6 x 70mm, 3 x 50.8mm and 3 x 50.8mm steering wheels to work with a range of vehicle setups.
    8 pushbuttons & 2 analogue inputs
    Wirelessly implement the in-vehicle commands in a fraction of the time with 8 instant steering button controls and 2 12 position analogue inputs which can be set as traction control settings or for engine mapping, giving you a wide range of adjustability at your fingertips.
    Using our PDM systems and free Race Studio 3 software will allow you to have complete control of the momentary push buttons to act as simple latching switches or more complex management.
    Customise Your Wheel Plate
    Upgrade your wheel plate with easy to apply adhesive stickers pre-cut and hard-wearing wheel plate stickers - available in 10 channel and 4 & 8 channel options - for a professional looking finish.
    Please Note: Images showing the steering wheel are for illustration purposes only. The steering wheel and sticker are to show how the complete setup could look and aren’t included as standard.
    Battery Life
    The 10 channel wireless wheel plate has a standard CR2 lithium battery with a guaranteed life of 3 years or 50,000 miles, so you don't need to worry about the battery going flat.
    The battery voltage is regularly transmitted to the CAN receiver with the intelligent system and then forwarded to the Aim device that gives you around 30 days notice if the battery needs to be replaced.
    With Race Studio 3 you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need.
    Race Studio 3 also allows you to download and analyse all data recorded by the system to your laptop/PC. With graphs, histograms and tables, you can study your lap and sector times to refine racing lines and braking points to enhance your racing performance.
    • Button plate front: Matt black, Textured acrylic
    • 176 x 154mm
    • Battery housing: ABS-UL94-VO
    • 54 X 38 X 23mm external
    • CR2 lithium battery
    • 50,000 miles active use
    • Pushbuttons: IP67
    • Assembly: 10 channel 285g
    What's In The Box
    • 10 channel wireless wheel plate
    • Connection harness
    • Aim sticker
    User Guide Technical sheet Race Studio 3 CAN Protocol
