10 Channel Sticker Sheets for Wireless Steering Wheel Plate
SKU: RBI-SS10
- £30.00
- £30.00
Customise your Wheel plate
With Race Studio 3 you can also analyse all data recorded and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances. ![]() |
- Rotary Stickers:
- 12 waterproof, 180 microns, vinyl stickers
- Low initial tack with high ultimate adhesion
- Overall sheet dimensions 148mm x 105mm
- 6 larger stickers have a 28mm outer diameter, 10mm inner diameter
- 6 smaller stickers have a 20mm outer diameter, 10mm inner diameter
- 180 motorsport stickers:
- 180 waterproof, 180 microns, vinyl stickers
- Low initial tack with high ultimate adhesive
- Overall sheet dimensions 310mm x 220mm
- Circle stickers have a 12mm internal diameter hole - apply before soldering
- Sausage stickers follow a 12mm diameter curve and can be retro-fitted where the switches are already soldered
- Two sticker sheets for buttons for 10 channel wheel plate. 180 stickers
- One sticker sheet for rotary switches for 10 channel wheel plate. 12 stickers
