Gå till produktinformation
1 av 1
Yamaha YZF- R1 & YZF-R6 AiM Solo 2 & Solo 2 DL Motorcycle Bracket
SKU: YAM-2-B
Vanligt pris
£60.00
Vanligt pris
Försäljningspris
£60.00
The AiM Yamaha motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
Yamaha bracket All necessary mounting hardware
Suitable for Solo 2 & Solo 2 DL
Yamaha Solo 2 & Solo 2 DL Bracket
The Yamaha YZF-R1 & YZF-R6 bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike.
Please Note: If you are unsure this bracket will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.
Also available is our Yamaha plug & play cable for the following bike models: (Sold Separately)
Yamaha YZF-R1 (YEC included) - 2004-2014 Yamaha YZF-R6 (YEC included) - 2004-2016
Yamaha YZF-R1 (YEC included) - 2009-2014 Yamaha YZF-R6 (YEC included) - 2004-2005
Example data protocols
  • Specifically designed Yamaha YZF-R1 & YZF-R6 bracket for the Solo 2 and Solo 2 DL
  • 1 Bracket
  • 2 spacers
  • 2 self-locking nuts M6
  • 4 washers M6
  • 2 self-locking nuts M4
  • 2 washers M4
  • 2 Allen screws with rounded head M6 x 60mm
  • 1 Bracket
  • 2 spacers
  • 4 washers M6
  • 2 washers M4
