Gå till produktinformation
1 av 2
Yamaha YZF-R1/R1M & YZF-R6 AiM EVO4S Logger Plug & Play Cable
SKU: YAM-1-PP-EVO
Vanligt pris
£67.00
Vanligt pris
Försäljningspris
£67.00
The AiM ECU plug & play cable has been specifically designed for Yamaha bikes. Allowing easy installation to the EVO4S Data Logger. With a 7-pin 712 male binder connection.
Yamaha plug & play cable 7 pin - 712 male binder connection
Receive data Suitable for EVO4S Data Logger
Yamaha Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Yamaha bike. This plug & play cable can be used for the EVO4S Data Logger.
Yamaha YZF-R1 - From 2015 Yamaha YZF-R1M - From 2015
Yamaha YZF-R6 - From 2017
Example data protocols
  • Below is a pinout drawing for the Yamaha YZF-R1/R1M & YZF-R6 EVO4S Data Logger plug & play connection cable
  • Yamaha YZF-R1/R1M & YZF-R6 EVO4S Data Logger Plug & Play connection cable
