The multi Cylinder ECU
SKU: ECU-MC
- Vanligt pris
- £670.00GBP
- Vanligt pris
- Försäljningspris
- £670.00GBP
For Engines up to 4 Cylinder with 4 injectors. The ecu is designed with automotive 32bit microcontroller and is equipped with advanced chip for dynamic vehicle control.
- High Current Ignition Power Stage
- Integrated Wide Band Lambda Sensor controller
- High Speed configurable CAN bus Line
- Internal memory for small data logging
- 6D integrated accelerometer and gyroscope
- Flexible inputs and outputs
- Editing in real time of calibration parameters
- Automotive Aptive/Delphi 64-way connector
- Two different ECU mounting for Hall or VRS crank sensor
