Gå till produktinformation
1 av 2
Suzuki GSX-R 1000 L7 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: SUZ-PP
Vanligt pris
£67.00
Vanligt pris
Försäljningspris
£67.00
Suzuki GSX-R 1000 L7 Solo 2 DL & EVO4S Logger Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for Suzuki bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
Suzuki plug & play cable 7 pin - 712 male binder connection
Suzuki Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Suzuki bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.
GSX-R 1000 L7 - 2017 onwards
Example data protocols
  • Below is a pinout drawing for the Suzuki Solo 2 DL and EVO4S Data Logger plug & play connection cable
  • Suzuki GSX-R 1000 L7 Plug & Play connection cable
