Gå till produktinformation
1 av 2
Link Mazda RX7Link (S6) - RX7S6X PlugIn ECU
SKU: RX7S6X
Vanligt pris
£1,050.00
Vanligt pris
Försäljningspris
£1,050.00
This ECU is designed for the RX7 series 6 13BT.
Suitable Applications:
FD3S Series 6 RX7
This ECU will support naturally aspirated, parallel twin or single turbo configurations. Does not support sequential control of the stock twin turbos.
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Gnd Sensor Ground Only
+5V Out Supply for MAP sensor
An Volt 5 Analog 0-5V input
An Volt 6 Analog 0-5V input
DI 6 Digital Input
  • G4X PlugIn ECU
  • Stickers
FD3S Series 6 RX7
CAN port
Staged injection
DI 6 Digital Input
  • G4X PlugIn ECU
  • Stickers
