Gå till produktinformation
1 av 1
Honda CBR 600RR, 1000RR AiM Solo 2 & Solo 2 DL Motorcycle Bracket
SKU: HON-B
Vanligt pris
£67.00
Vanligt pris
Försäljningspris
£67.00
The AiM Honda motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
Honda bracket All necessary mounting hardware
Suitable for Solo 2 & Solo 2 DL
Honda Solo 2 & Solo 2 DL Bracket
The Honda CBR 600RR, CBR 1000RR bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike.
Please Note: The bracket is only compatible with the CBR 600RR original triple clamp.
Also available is our Honda plug & play cable for the following bike models: (Sold Separately)
CBR 600RR - 2003-2019 CBR 600RR HRC with D11 marked ECU - 2013-2015
CBR 1000RR - 2004-2016 CBR 1000RR HRC - 2014-2016
Example data protocols
  • Specifically designed Honda bracket for the Solo 2 and Solo 2 DL
  • 1 Bracket
  • 1 washer
  • 1 Allen screw with rounded head M6 x 60
  • 1 rubber dowel
  • 1 Bracket
  • 1 washer
  • 1 rubber dowel
