Deutsch Male & Female DTM Plug & Pins including Wedge Lock
SKU: P-DTM-2-F
- Vanligt pris
- £8.00
- Vanligt pris
- Försäljningspris
- £8.00
The Deutsch male & Female DTM Plug & Pins, including wedge lock, are ideal connectors for PDM use and are often used in engine compartments and transmission tunnels.
Male & Female DTM plugs | Pins & wedge lock |
2 to 12 way options | |
The plug & pins are suited for applications that require a secure & reliable connector in harsh environments, like under the hood of your car, transmission tunnels and other areas that need secure connections in both power and signal.
- Tactile and audible connector mating
- Rugged thermoplastic connector housing
- Hand insertable/removable connects
- Operating temperature range: -55 to +125°C
- Positive contact retention
- 1 x DTM Deutsch plug, pins, wedge lock
The Deutsch male & Female DTM Plug & Pins, including wedge lock, are ideal connectors for PDM use and are often used in engine compartments and transmission tunnels.Key Features :
The Deutsch male & Female DTM Plug & Pins, including wedge lock, are ideal connectors for PDM use and are often used in engine compartments and transmission tunnels.The plug & pins are suited for applications that require a secure & reliable connector in harsh environments, like under the hood of your car, transmission tunnels and other areas that need secure connections in both power and signal.
