AiM MX2E Adapter Harness for Lotus Elise/Exige 2004 - 2007
SKU: MX2E-AH
- Vanligt pris
- £60.00
- Vanligt pris
- Försäljningspris
- £60.00
The wiring harness adaptor will enable the MX2E dash logger to work with specific Lotus Elise and Exige models.
Designed to fit the MX2E dash logger | Required for some Lotus cars |
Simple plugin installation |
The wiring harness adaptor will enable the MX2E dash logger to work with specific Lotus Elise and Exige models. The adaptor plugs in-between the dash and the vehicles wiring loom.
- Designed to fit MX2E
- Simple plugin installation
- MX2E Adaptor Harness
The wiring harness adaptor will enable the MX2E dash logger to work with specific Lotus Elise and Exige models.Key Features :
The wiring harness adaptor will enable the MX2E dash logger to work with specific Lotus Elise and Exige models. The adaptor plugs in-between the dash and the vehicles wiring loom.Technical
