Gå till produktinformation
1 av 4
AiM Oil / Fuel Pressure Sensor M10 0-10 Bar Motorcycle
SKU: S-P-O-M10-MC
Vanligt pris
£190.00
Vanligt pris
Försäljningspris
£190.00
The AiM M10 0-10 Bar pressure sensor is suitable for oil and fuel pressure readings and able to read pressures up to 10 bars.
M10 0-10 Bar 4 pins 719 male binder
The M10 0-10 Bar pressure sensors are fitted with male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers. Many things affect the various engine pressures, and knowing that your engine has the correct amount is paramount to longevity and performance. Suitable for oil, fuel and water pressure readings.
  • Supply: 8-16V
  • Consumption: < 10 mA
  • Sealing: IP66
  • Weight: 30g
  • Cable Length: 400mm
  • Thread: M10
  • AiM Oil/Fuel pressure sensor M10 0-10 Bar
  • Supply: 8-16V
  • Sealing: IP66
  • Weight: 30g
  • Thread: M10
