Gå till produktinformation
1 av 2
BMW S1000RR AiM Solo 2 DL Motorcycle Cable & Bracket
SKU: BMW-PP-BMW-B
Vanligt pris
£120.00
Vanligt pris
Försäljningspris
£120.00
The AiM BMW  motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.
BMW cable & bracket 7 pin - 712 male binder connection
Bracket suitable for Solo 2 & Solo 2 DL
BMW Solo 2 DL Cable & Bracket
The AiM ECU plug & play cable has been specifically designed for the BMW bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.
The AiM BMW bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
The plug & play cable currently fits the following BMW bike models:
S1000RR - 2009-2014 S1000RR - From 2015
S1000RR HP4 - 2013-2014
Example data protocols
  • Specifically designed BMW S1000RR Plug & play cable and bracket for the Solo 2 DL
  • Below is the pinout drawing for the BMW plug & play connection cable.
  • BMW plug & play connection cable
  • 1 bracket
  • 1 toothed washer
  • 1 rubber dowel
  • 1 spacer
  • 1 bracket
  • 1 toothed washer
  • 1 rubber dowel
  • 1 spacer
