AiM Thermocouple Patch Lead TC - TC Yellow
SKU: P-TC-TC-5
- Vanligt pris
- £40.00
- Vanligt pris
- Försäljningspris
- £40.00
The AiM thermocouple patch/extension leads are used to extend thermocouple patch leads that connect AiM thermocouple sensors.
TC-TC Yellow | Male to female 2 pin |
The AiM thermocouple patch/extension leads are used to extend thermocouple patch leads that connect an AiM thermocouple sensor such as an EGT (exhaust gas temperature) or a CHT (cylinder head temperature) to an AiM EVO5, MXL2, MXG or MXS. Available in different lengths to suit your application from 50cm to 3m.
High-quality extension leads that are designed to perform in challenging motorsport environments
Very quick and easy to use connectors
- TC-TC Yellow Patch Lead
- Male to Female 2 Pin
- Available in 50cm to 3m lengths
- 1 x Thermocouple TC-TC Yellow Patch Lead
The AiM thermocouple patch/extension leads are used to extend thermocouple patch leads that connect AiM thermocouple sensors.Key Features :
The AiM thermocouple patch/extension leads are used to extend thermocouple patch leads that connect an AiM thermocouple sensor such as an EGT (exhaust gas temperature) or a CHT (cylinder head temperature) to an AiM EVO5, MXL2, MXG or MXS. Available in different lengths to suit your application from 50cm to 3m.High-quality extension leads that are designed to perform in challenging motorsport environments
