AiM Taipan K Motocross ECU Plug & Play
SKU: C-ECU
- Vanligt pris
- £480.00
- Vanligt pris
- Försäljningspris
- £480.00
+ moms (endast Storbritannien)
Aim Taipan K ECU Plug & Play Engine Control Unit
Taipan are the brand-new aftermarket plug & play ECUs created by AiM, exclusively designed for off-road motorcycles.
Thanks to their high technology 32-bit core, they represent an important step forward to improve the performances of your motorcycle, without sacrificing reliability and smoothness.
The latest addition, the Taipan K, was specifically designed for 2 stroke KTM/Husqvarna/GasGas 2024.
This specific TaipanECU is unprogrammed. It can be configured for any brand or model bike you require. You will need the UC Bridge Tuner to enable this process.
Once the unprogrammed TaipanECU has been configured with a dedicated brand or model it can not be changed. You will be able to modify the maps written into the ECU but the brand or model which has been configured can not be changed.
Taipan ECU Connections
The Taipan ECU has 3 connectors :
Main Connector - Compatible with 2 stroke KTM/Husqvarna/GasGas 2024
2nd CAN Connector - Connect to the UC Bridge, to communicate with the PC.
The possibility to configure and to set your bike, thank to the many different strategies and corrections implemented, is really endless. Here down, a list of the most important:
- Injection main alpha-n
- Injection main speed-density
- Injection crank correction
- Pre-injection
- Injection BAP correction
- Injection EWT correction
- Injection IAT correction
- Injector battery correction
- Injector 2
- Ignition BAP correction
- Ignition EWT correction
- Ignition IAT correction
- Ignition opening transient correction
- Ignition closing transient correction
- Launch control
- Injection launch control main table
- Ignition launch control main table
- Quick shift
- Traction control
High Technology 32-bit Core
Engine control requires precision. At 20,000 RPM the TaipanECU guarantees the precision of 1/10 of the degree: this means an accuracy within 0.8 uses for turning the spark ON!
Tuner License :
This is the Tuner that is required to configure the unprogrammed Taipan ECU.
AiM Taipan ECU Plug & Play Engine Control Unit
- Two 0-5V analog inputs sampled @ 1,000 Hz each, could be alternatively used as switch to ground
- One low side driver (1A)
- 1 CAN bus for calibration purposes
- IMU
- Pitch/Roll
- Power consumption: 150 mA
- Connectors: n.1 JST 04T-JWPF-VSLE-S connector, n.1 JST 08R-JWPF-VSLE-D connector, n.1 64 pins male connector
- Body: PA6 + 30% glass ber + EPDM cover
- Dimensions: 112x100x40.8 mm
- Weight: 390 g approx
- ECU Taipan K Control Unit
- Your Choice of Accessories
The possibility to configure and to set your bike, thank to the many different strategies and corrections implemented, is really endless. Here down, a list of the most important:- Injection main alpha-n
- Pre-injection
- Injector 2
- Launch control
- Quick shift
- Traction control
Tuner License :
- IMU
- Pitch/Roll
