Gå till produktinformation
1 av 1
Aim Strada 1.2 23 Pin Car Analogue Loom MXS, MXP, MXG
SKU: MX-S-L-AN
Vanligt pris
£160.00
Vanligt pris
Försäljningspris
£160.00
Aim 23 Pin Strada 1.2 Analogue Loom for MXS, MXP, MXG
The Aim 23 pin AMP connection harness is an optional extra for the Strada MXS, MXP, MXG dash displays.
Fits MXS, MXG, MXG dashes Replacement for original wiring
 23 pin AMP female connector 4 pin binder 719 female
 4 cables
23 Pin Analogue Loom
The Aim 23 pin AMP connector is an optional harness with pre-wired connections. Offering 4 analogue, speed and lap channels all being terminated with 719 female binder plugs.
These plugs can be extended to suit your requirements by purchasing the 719-719 patch leads which are available in the accessories tab.
The 23 pin AMP connection provides:
Analogue channels 1-4
Speed
Lap
RS232tx/rx
Digital output
CAM2+/-
Please Note: This harness is an optional tool to help you gain more data and add extra sensors to your kit should you require them.
These are some of the items that can be added to your car to increase performance and data.
  • 23 pins AMP female connector
  • X 4 Cables - 1 x 0.5
  • 4 X 0.35 cables +
  • 3 X 0.35 cables
  • 4 pins Binder 719 female connector
  • 23 Pin Strada 1.2 Analogue Loom
 4 cables
Speed
Lap
RS232tx/rx
Digital output
CAM2+/-
  • 4 X 0.35 cables +
  • 3 X 0.35 cables
