AiM SmartyCam HD 2.1 Replacement Lens Ring Motocross
SKU: SM-EC
- Vanligt pris
- £20.00
- Vanligt pris
- Försäljningspris
- £20.00
The AiM replacement lens ring is for the SmartyCam HD 2.1 camera.
Fits SmartyCam HD 2.1 | Ideal replacement or spare |
Steel lens ring |
AiM SmartyCam HD 2.1 Glass Replacement Kit
The AiM replacement lens ring is for the SmartyCam HD 2.1 camera. It is needed as a replacement should the lens ring become damaged or spare to keep with your camera kit.
Steel lens ring
For the SmartyCam HD 2.1
- Replacement Lens Ring - For SmartyCam HD 2.1
- AiM SmartyCam HD 2.1 Replacement Lens Ring
The AiM replacement lens ring is for the SmartyCam HD 2.1 camera.Key Features :
Steel lens ring |
The AiM replacement lens ring is for the SmartyCam HD 2.1 camera. It is needed as a replacement should the lens ring become damaged or spare to keep with your camera kit.Steel lens ring
