Gå till produktinformation
1 av 2
AiM SmartyCam GP HD Bullet Cam Roll Cage Mount 2.1 & 2.2 Offroad
SKU: SM-VB-GP-MX
Vanligt pris
£80.00
Vanligt pris
Försäljningspris
£80.00
Fits the SmartyCam GP HD camera Ball & socket adjustment system
Clamp to a wide range of diameter tubing For SmartyCam GP HD 2.1 & 2.2
Roll Cage Mount
  • For use with SmartyCam GP HD 2.1 & 2.2
  • Arm height 60mm ( 2.36 inches)
  • Handlebar bracket
  • 60mm arm
  • Ball head
  • Bullet cam bracket
Technical sheet Race Studio 3
Roll Cage Mount
  • Handlebar bracket
  • 60mm arm
  • Ball head
