Car Potentiometer Replacement Rose End Fitting
SKU: CASUS-POT-END-RJ
- Vanligt pris
- £8.50
- Vanligt pris
- Försäljningspris
- £8.50
Replacement rose end joint fitting for the suspension potentiometer.
Replacement rose end fitting | Spare or replacement parts |
The Potentiometer rose joint fitting is a replacement part to fit the suspension potentiometer used to measure displacement between two points using a sensor.
Use as a replacement or spare part.
One Potentiometer Rose End Fitting Replacement Supplied.
- Replacement Potentiometer Rose End Fitting
- 1 x Rose End Fitting Potentiometer Replacement Fitting
Replacement rose end joint fitting for the suspension potentiometer.Key Features :
The Potentiometer rose joint fitting is a replacement part to fit the suspension potentiometer used to measure displacement between two points using a sensor.Use as a replacement or spare part.
