Gå till produktinformation
1 av 6
AiM PDM32 Pre Assigned 3m Black & Grey Connection Harness
SKU: PDM-L-GB
Vanligt pris
£445.00
Vanligt pris
Försäljningspris
£445.00
AiM PDM32 Pre Assigned 3m, Black & Grey Connection Harness
The AiM wiring harness is a pre-assigned harness made from high-quality professional cables suitable for the AiM PDM32 advanced power distribution module data logger kits.
Colour coded & tagged cables Provides easy installation
Suitable for PDM08 & PDM32 2 x Harness in kit
The AiM wiring harness is a pre-assigned harness made from high-quality professional cables suitable for the AiM PDM32 advanced power distribution module data logger kits. Each of the wires on the harness is colour coded and tagged to help provide an easy installation.
Suitable for the PDM32
3 metres in length
Pre-wired connector for the easiest of installations
  • AiM PDM pre-assigned 3 meters black & grey connection harness
  • See below for pinout for black and grey connectors
AiM PDM Pre Assigned 3m, Black & Grey Connection Harness
  • Pre-assigned 3m PDM harness 1 x Black connection harness and 1 x Grey connection harness
3 metres in length
