Gå till produktinformation
1 av 4
AiM Oil / Fuel Pressure Sensor M10 0-5 Bar Motorcycle
SKU: S-P-F-M10-MC
Vanligt pris
£190.00
Vanligt pris
Försäljningspris
£190.00
The AiM M10 pressure sensor is suitable for oil, fuel and water pressure readings, reading pressures up to 5 bars.
M10 - 0-5 bars 4 pins 719 male binder
The M10 0-5 bar pressure sensor is suitable for oil, fuel and water pressure readings, reading pressures up to 5 bars.
The M10 - 0-5 bar pressure sensor is fitted with a male four pins 719 binder connector to suit our loggers and dash display/loggers.
This sensor is also available in a 0-5 Bar 3/8 24. Available in the accessories tab.
  • Supply: 8-16V
  • Consumption: < 10 mA
  • Sealing: IP66
  • Weight: 30g
  • Cable Length: 400mm
  • Thread: M10
  • AiM M10 0-5bar pressure sensor
  • Supply: 8-16V
  • Sealing: IP66
  • Weight: 30g
  • Thread: M10
