AiM MXG Dash Bracket
SKU: UP-MXG
- Vanligt pris
- £20.00
- Vanligt pris
- Försäljningspris
- £20.00
MXG Dash Mount
The MXG dash bracket has been designed to fit the MXG to the steering wheel column.
Key Features:
MXG Dash Bracket
Due to the size of the Dash, this will probably more likely be used with our single mount centre hub on the steering column or our chassis weld-on and bolt-on tabs. Though this will work without steering wheel mounts if you prefer. 160mm x 60mm bolt holes for the dash. Optional Weld on the tab for your chassis or steering column. 2mm thick in Raw Stainless Steel |
AiM Technologies are committed to supplying, professional engineers with quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the marketplace today. |
Unlock your potential |
- 160mm x 60mm bolt holes for dash
- 2mm thick in raw stainless steel
MXG Dash Mount
Key Features:
MXG Dash Bracket
Whats In The Box
