Gå till produktinformation
1 av 5
AIM LCU-One S for Motorcycle
SKU: LCU1S
Vanligt pris
£270.00
Vanligt pris
Försäljningspris
£270.00
Total control of your engine
Overview
LCU-One S controller allows to perfectly tune the carburetion of your engine to keeping it at its best and improve the engine's performances. lt uses a wide band Bosch LSU 4.9 sensor, used for its capacity of saving the originai calibration for the duration of the sensor's life. In fact, Bosch LSU 4.9 probe has been designed to last for more than 100,000 km on a stock car.
Precision and reliability
LCU-One S can detect accurate Lambda value from 0.65 to 1.6, offering an extremely precise measurement, very useful for engine tuning. Through the analysis of the remaining oxygen, LCU-One S points out a possible oxygen excess/lack in the carburetion and provides essential information for 2 strokes and 4 strokes engines. The configuration of Stoichiometric ratio allows LCU-One S to be used on petrol, diesel and also alternative fuel powered engines.
  • Sensor Compatibility: BOSCH LSU 4.9
  • Power supply voltage: 9÷15 V
  • Power supply current: 50 mA + sensor heater current typical 750 mA up to 2 A on cold sensor
  • Materials: Latigloss 57
  • Dimensions: 43.4 x 30 x 18.4 mm
  • Weight: 70 g
  • Waterproof: IP67
optional: BOSCH LSU 4.9 Lambda probe + Thread iron ring for installation
Overview
  • Weight: 70 g
  • Waterproof: IP67
