AiM Hall Effect Wheel Speed Sensor
SKU: S-S-ABS
- Vanligt pris
- £105.00
- Vanligt pris
- Försäljningspris
- £105.00
AiM M12 Hall Speed Pickup 719 Binder
The AiM Hall Effect Sensor is a non-contact device that needs a metallic trigger to pass in front of it.
Hall effect wheel speed sensor | 4 pin 719 binder connector |
The Hall Effect Sensor is a non-contact device that needs a metallic trigger to pass in front of it. Again, a bracket will usually need to be fabricated to mount the sensor in a suitable position. Would you please ensure that the distance between the sensor and trigger is in a 0.5 – 2.0 mm (0.007-0.07 inches) range? Cable length approximately 2.0m. A higher-quality Honeywell ABS hall effect sensor is also available.
The 719 connection will suit the MXL2, all MX Series including Strada. Use with 719-719 patch lead.
- Power supply voltage: 4.5-24 VDC
- Current consumption: 10 mA (typical) 20 mA (max)
- Output signal type: 0-5V
- Max current output: 20mA
- Max operating freqency: 100kHz
- Sensibility distance: 0.5 to 2mm (from 0.007 to 0.07 inches)
- Recommended distance: 1mm
- Operating temperature range: from - 40 to 150°C (from 104 to 302F)
- Cable length: 80mm
- 1 x Hall Effect Speed Sensor
The AiM Hall Effect Sensor is a non-contact device that needs a metallic trigger to pass in front of it.Key Features :
The Hall Effect Sensor is a non-contact device that needs a metallic trigger to pass in front of it. Again, a bracket will usually need to be fabricated to mount the sensor in a suitable position. Would you please ensure that the distance between the sensor and trigger is in a 0.5 – 2.0 mm (0.007-0.07 inches) range? Cable length approximately 2.0m. A higher-quality Honeywell ABS hall effect sensor is also available.The 719 connection will suit the MXL2, all MX Series including Strada. Use with 719-719 patch lead.
