Gå till produktinformation
1 av 5
AiM GPS09 Module Roof Mount Version For SmartyCam 2.2
SKU: GPS-CR2
Vanligt pris
£310.00
Vanligt pris
Försäljningspris
£310.00
AiM GPS09 Roof Version Module
This roof version is available in 2m or 4m and specifically designed for easy installation. This version also works well when fitted to race bike fairings, as the module can be bolted through the fairing with the advantage that the cable can be detached at the GPS module making removal quicker and more convenient.
GPS09 Benefits
On the Track
AiM GPS09 Module
  • Dimenstions: 64.8 x 53.2 x 19.7mm
  • Weight: 60.5g
GPS09 pinout
AiM GPS09 Module
  • GPS09 Module
GPS09 Benefits
On the Track
AiM GPS09 Module
  • Weight: 60.5g
GPS09 pinout
AiM GPS09 Module
  • GPS09 Module
