Dual Brake Pressure Mounting T-Piece Kit
SKU: S-P-DP
- Vanligt pris
- £86.00
- Vanligt pris
- Försäljningspris
- £86.00
The Dual Brake Pressure Monitoring T-Piece can be used with the M10 brake pressure sensors, which have a 719 plastic binder connector to fit AiM systems or extension leads.
Suitable for M10 brake pressure sensors | Dual pressure T-piece |
Used for Motorsport racing, this dual brake pressure kit allows you to see:
Brake pressure
Braking points (start and end)
Driver alertness
Brake system status
- Brake Pressure
- Braking Points (start & end)
- Driver Alertness
- Brake System Staus
- 1 x Dual Brake Pressure Mounting T-Piece
The Dual Brake Pressure Monitoring T-Piece can be used with the M10 brake pressure sensors, which have a 719 plastic binder connector to fit AiM systems or extension leads.Key Features :
The Dual Brake Pressure Monitoring T-Piece can be used with the M10 brake pressure sensors, which have a 719 plastic binder connector to fit AiM systems or extension leads.Used for Motorsport racing, this dual brake pressure kit allows you to see:
Brake pressure
Driver alertness
Brake system status
- Brake Pressure
- Driver Alertness
