Gå till produktinformation
1 av 7
AiM 712 Male & Female Binder Plugs
SKU: P-712-3-M
Vanligt pris
£15.00
Vanligt pris
Försäljningspris
£15.00
The AiM 14 pin plug and pins are ideal if you need a replacement or to keep them as spares.
712 Binder plug Male or Female options
Metal Binder Strong & Reliable
The AiM 712 binder connector is ideal if you need to replace a broken, damaged connector or you just want a refresh. The connectors are robust, reliable, and perfect if you are shortening, making custom length cables, or adding additional sensors or extension cables to your AiM system.
Available in Male & Female 3,4,5 pins.
Ideal for replacing broken plugs or when adding sensors to your AiM system.
High-quality connectors designed for the rigours of Motorsport.
  • 712 Binder Plug available in:
  • Male - 3, 4, 5 pin
  • Female - 3, 4, 5 pin
  • X 1 AiM 712 Binder Plug Male or Female
