AiM SmartyCam 2.2 GP HD Extension Lead CAN Harness
SKU: P-712-712-MM-5-5
- Vanligt pris
- £40.00
- Vanligt pris
- Försäljningspris
- £40.00
The AiM CAN harness is required to connect the SmartyCam 2.2 GP HD.
Suitable for 2.2 GP HD | CAN harness |
Available in 0.5m, 1m, 2m and 4m |
AiM SmartyCam 2.1 HD & GP HD Extension Lead CAN Harness
The AiM CAN harness for the SmartyCam 2.2 GP HD SmartyCam camera. This lead is required to connect the SmartyCam to an AiM dash/logger or data hub.
712-5 pin male to 712-5 pin male
High-quality cables and connectors
Provides you with flexibility for better SmartyCam location
- CAN Harness
- 712 5 pin male to 712 5 pin male
- Suitable for SmartyCam 2.2 GP HD
- 1 x SmartyCam 2.2 GP HD Extension CAN Cable
The AiM CAN harness is required to connect the SmartyCam 2.2 GP HD.Key Features :
The AiM CAN harness for the SmartyCam 2.2 GP HD SmartyCam camera. This lead is required to connect the SmartyCam to an AiM dash/logger or data hub.712-5 pin male to 712-5 pin male
- CAN Harness
