Gå till produktinformation
1 av 1
AiM 37 Pin Connector and Pins MXS, MXP, MXG, MXL2 Female Deutsch Connector
SKU: P-37P-5CN837F00
Vanligt pris
£125.00
Vanligt pris
Försäljningspris
£125.00
The AiM 37 pin plug and pins are ideal if you need a replacement or to keep them as spares.
Suitable for MX Series, MXL2 37 pins, One plug
Ideal for replacement or spares
The AiM Female Deutsch electrical connector is suitable with the AiM MX Series (MXL2, MXS, MXG, MXP) dashes.
Use as a replacement part or as part of building a wiring loom.
  • 37 Pins Female Deutsch Connector
  • 37 Pins
  • Plastic Pin Installation Tool
  • AiM 37 pins connector kit
  • 37 Pins
