Gå till produktinformation
1 av 1
AiM 22 Pin Connector Pins MXS, MXP, MXG, MXL 2 Female Deutsch Connector
SKU: P-22P-5CN822F00-MC
Vanligt pris
£180.00
Vanligt pris
Försäljningspris
£180.00
AiM 22 Pin Connector and Pins MXS, MXP, MXG, MXL2 Female Deutsch Connector
The AiM 22 pin plug and pins are ideal if you need a replacement or to keep them as spares.
Suitable for MX Series, MXL2 22 pins, One plug
Ideal for replacement or spares
The AiM Female Deutsch electrical connector is suitable with the AiM MX Series (MXL2, MXS, MXG, MXP) dashes.
Use as a replacement part or as part of building a wiring loom.
  • 22 Pins Female Deutsch Connector
  • 22 Pins
  • Plastic Pin Installation Tool
  • AiM 22 pins connector kit
  • 22 Pins
