10 Channel Sticker Sheets for Wireless Steering Wheel Plate
SKU: RBI-SS10
- Vanligt pris
- £30.00
- Vanligt pris
- Försäljningspris
- £30.00
Racing and track days made faster and safer knowing exactly where your buttons are on your Motorsport wheel plate.
These stickers fit our wireless wheel plates.
Customise your button plate exactly how you like it.
This kit offers an incredible amount of stickers for you to choose from with 180 motorsport stickers. Choose your icons and text design with a variety of looks to suit your requirements.
The 12 stickers on the rotary sticker sheet have been designed by experts from the racing and kit car world. These stickers are used on the rotary switches on your wheel plate. Offering six large stickers and six smaller stickers and in a choice of black or bright yellow.
Please Note: The wheel plate image above shows how your button plate could look with stickers applied. Wheel Plate not included.
Customise your Wheel plate
The stickers are pre-cut, hardwearing and professionally printed on tough vinyl with environment protection applied.
The stickers have been designed to specifically surround the buttons allowing a perfect fit on your button plate.
Three sticker sheets are supplied with this kit. The different colour options allow you to apply stickers to the more essential buttons you want to stand out.
The rotary switch stickers are available in black numbers on a yellow background or white numbers on a black background.
The stickers are water proof and fade resistant, so they wont peel off when they get wet.
- Rotary Stickers:
- 12 waterproof, 180 microns, vinyl stickers
- Low initial tack with high ultimate adhesion
- Overall sheet dimensions 148mm x 105mm
- 6 larger stickers have a 28mm outer diameter, 10mm inner diameter
- 6 smaller stickers have a 20mm outer diameter, 10mm inner diameter
- 180 motorsport stickers:
- 180 waterproof, 180 microns, vinyl stickers
- Low initial tack with high ultimate adhesive
- Overall sheet dimensions 310mm x 220mm
- Circle stickers have a 12mm internal diameter hole - apply before soldering
- Sausage stickers follow a 12mm diameter curve and can be retro-fitted where the switches are already soldered
- Two sticker sheets for buttons for 10 channel wheel plate. 180 stickers
- One sticker sheet for rotary switches for 10 channel wheel plate. 12 stickers
- Rotary Stickers:
