Skip to product information
1 of 5
Yamaha YZF-R1/R1M & YZR-R6 AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
SKU: SOLO2-K-YAM-1-SM-CAM-GP-2-SM-GPC-XB1SGPH22B67L200-V0256934CS-X47SOLO2DL02
£2,210.00
£2,210.00
Yamaha YZF-R1/R1M & YZF-R6 AiM Solo 2 DL & SmartyCam 3 GP  Motorcycle Plug & Play Lap Timer Track Day Kit
The Yamaha plug & play kit combined with the Solo 2 DL and SmartyCam 3 GP  gives you the ultimate track day experience.
Database with more than 4,000 tracks worldwide Yamaha ECU connection cable
This ultimate track day kit has been specifically designed for Yamaha bikes. The kit includes a plug & play interface cable and bracket for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Yamaha ECU will give you all the engine performance information you need to help improve your driving performance.
SmartyCam 3 GP Features:
Yamaha YZF-R1 - From 2015 Yamaha YZF-R1M - From 2015
Yamaha YZF-R6 - From 2017
Powerful Combination
Yamaha YZF-R1
SmartyCam 3 GP
Automatic Start/Stop
Yamaha YZF-R1
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
  • SmartyCam 3 GP
  • CMOS sensor: Global Shutter
  • Video Out: 3G-SDI
  • External power: 9-15 Volt
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Body: Anodised Aluminium
  • Dimensions: Main Body -154.4x109.6 x 42mm, Bullet Camera - 24diam x 48.2mm
  • Waterproof: IP65
  • Solo 2 DL
  • Power cable with AC adapter
  • SmartyCam 3 GP - Bullet Cam
  • External CAN cable 2m
  • External power cable
  • Yamaha Plug & Play connection cable
  • Bracket
  • 1 rubber dowel
  • 1 Allen screw with flat head M6
  • 1 rubber washer
  • 2 Allen screws with flat head M4 x 10
Yamaha YZF-R1
SmartyCam 3 GP
Yamaha YZF-R1
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • SmartyCam 3 GP
  • Video Out: 3G-SDI
  • Waterproof: IP65
  • Solo 2 DL
  • Bracket
  • 1 rubber dowel
  • 1 rubber washer
