Skip to product information
1 of 3
Yamaha YZF-R1/R1M & YZF-R6 AiM Solo 2 DL Plug & Play Cable
SKU: YAM-1-PP
£67.00
£67.00
The AiM ECU plug & play cable has been specifically designed for Yamaha bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
Yamaha plug & play cable 7 pin - 712 male binder connection
Yamaha Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Yamaha bike. This plug & play cable can be used for the Solo 2 DL.
Yamaha YZF-R1 - From 2015 Yamaha YZF-R1M - From 2015
Yamaha YZF-R6 - From 2017
Example data protocols
  • Below is a pinout drawing for the Yamaha YZF-R1/R1M & YZF-R6 Solo 2 DL plug & play connection cable
  • Yamaha YZF-R1/R1M & YZF-R6 Solo 2 DL Plug & Play connection cable
