    Verbatim Pro U3 64GB UHS-3 (U3) SD Card - AimShop.com
    SD-64
    In stock, ready to ship
    £25.00
    £25.00
    The Verbatim Pro memory cards gives professional level performance and are a great addition to our Aim SmartyCam cameras.
    Key Features:
    64GB memory  Water & shock resistant
     Class 3 Suitable for Aim SmartyCams
     64GB SD Card
    The Verbatim Pro memory card gives a Pro level performance to advanced cameras and HD camcorders.
    UHS Speed Class 3 (U3) rating means you can capture 4K ultra HD and Full HD video then transfer quickly to your computer for viewing and editing.
    Suitable for 4K ultra HD video capture and compatible with any device with SDHC/SDXC memory card slot.
    Read Speed: up to 90MB/Sec*
    Write Speed: up to 45MB/Sec*
    *SDXC compatible host device required
    **UHS-1 compatible device required, actual performance may vary depending on host device, interface and usage conditions.
    Product Details
    UHS Speed Class 3 (U3) for fast file transfer
    Water and Shock resistant
    Read Speed: up to 90MB/Sec**
    Write Speed: up to 45MB/Sec**
    Compatible with cameras and SDHC or SDXC supporting host devices.
    • Product Dimensions: 32mm x 24mm x 2.1mm
    • Product Weight: 1.8 grams
    • Pack Dimensions: 90mm x 3mm x 135mm (W x D x H)
    • Pack Weight: 17.7 grams
    • 1 x Verbatim SD Card
