Suzuki GSX-R 1000 L7 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: SUZ-PP
- £67.00
- £67.00
Suzuki GSX-R 1000 L7 Solo 2 DL & EVO4S Logger Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for Suzuki bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
Suzuki plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL & EVO4S Data Logger |
Suzuki Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Suzuki bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.
GSX-R 1000 L7 - 2017 onwards | |
Example data protocols
- Below is a pinout drawing for the Suzuki Solo 2 DL and EVO4S Data Logger plug & play connection cable
- Suzuki GSX-R 1000 L7 Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Suzuki bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Suzuki bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Suzuki bike models:GSX-R 1000 L7 - 2017 onwards | |
