Kawasaki ZX-10R AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-KAW
- £710.00
- £710.00
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Kawasaki this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide | Kawasaki ECU connection cable |
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Solo-2-DL-Display-Colours_240x240.gif?v=1613590480)
This kit has been specifically designed for Kawaski bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Kawaski ECU will give you all the engine performance information you need to help improve your driving performance.
The plug & play cable currently fits the following Kawasaki bike models:
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Kawasaki_Bike_2.png?v=1620635533)
Kawasaki Ninja ZX-10R MY2011 - 2001-2015 | Kawasaki Ninja ZX-10R MY2011 Racing Kit - 2011-2015 |
Please Note: The bracket fits Kawasaki models from 2016.
The Kawasaki ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
- Display: Graphical
- GPS: 10 Hz
- External power: 12 V
- Memory: 4 GB
Below is the pinout drawing for the Kawasaki plug & play connection cable.
- Solo 2 DL
- Power cable with AC adapter
- User manual
- AiM Kawasaki Connection Cable
- Bracket
- 2 toothed washers
- 2 Allen screws M6 x 12mm
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Kawasaki this kit will ensure an improvement in your driving performance.Key Features :
This kit has been specifically designed for Kawaski bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Kawaski ECU will give you all the engine performance information you need to help improve your driving performance.Plug & Play
The plug & play cable currently fits the following Kawasaki bike models:![](https://cdn.shopify.com/s/files/1/0214/9392/files/Kawasaki_Bike_2.png?v=1620635533)
The Kawasaki ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Aim_Solo_2_DL_Wifi_Communication_With_PC.png?v=1614779557)
The Solo 2 DL has integrated Wi-Fi, so if you want to review your data in more depth simply transfer your data securely and quickly onto a laptop or computer up to 50m away without the need for connectors and cables. You can then import the data into the Race Studio 3 software.![](https://cdn.shopify.com/s/files/1/0214/9392/files/Yamaha_YZF-R1_2009_-_2014_AiM_Solo_2_DL_Plug_Play_Lap_Timer_Kit_54b3a036-e2b6-4d6e-9ab0-a7c03c0f64b0.png?v=1619781880)
These are some of the items that can be added to our Solo 2 DL for incrementing the performance and data acquired.![](https://cdn.shopify.com/s/files/1/0214/9392/files/Free_Download.png?v=1629297377)
- GPS: 10 Hz
- Memory: 4 GB
- Solo 2 DL
- User manual
- Bracket
- 2 toothed washers
![Kawasaki ZX-10R AiM Solo 2 DL Plug & Play Lap Timer Kit - AimShop.com](http://www.aimshop.com/cdn/shop/products/KawasakiZX-6R_ZX-10R_ZX-10RAiMSolo2DLPlug_PlayLapTimerKit2_1445x.png?v=1619784301)
![Kawasaki ZX-10R AiM Solo 2 DL Plug & Play Lap Timer Kit - AimShop.com](http://www.aimshop.com/cdn/shop/products/KawasakiZX-6R_ZX-10R_ZX-10RAiMSolo2DLPlug_PlayLapTimerKit3_1445x.png?v=1619784366)
![Kawasaki ZX-10R AiM Solo 2 DL Plug & Play Lap Timer Kit - AimShop.com](http://www.aimshop.com/cdn/shop/products/Solo2DLRearView_withMagnets_2compressed_700c3d35-8773-4920-b54e-a13b160a691c_1445x.png?v=1641560362)
![Kawasaki ZX-10R AiM Solo 2 DL Plug & Play Lap Timer Kit - AimShop.com](http://www.aimshop.com/cdn/shop/products/Solo2DLBottomCompressed_41739228-986a-43de-bcaf-7bca87c92724_1445x.jpg?v=1641891706)
