Skip to product information
1 of 6
AiM CAN Expansion Keypad K15,K8 & K6
SKU: k6
£185.00
£185.00
K6/K8/K15
The CAN-Bus Keypads Series
Compact, Fully customizable, water and dust proof
The K6, K8 and K15 are compact keypads based on CAN-Bus protocol.
The devices are water and dust resistant and can be installed both inside and outside the cockpit. They are fully customizable and proposed with a wide range of interchangeble inserts sold seperatly. View Inserts
The keypads will enable you to have your very own selected buttons at your fingertips. Available in 6, 8 and 15 key keypads.
Reconfigurable buttons Programmable RGB LEDs
LED backlit rings and icons Momentary, toggle and multi-status
2 blinking mode Wide range of inserts
CAN-Bus system compatible Vertical or horizontal mount
Status restore option
  • Reconfigurable buttons
  • Programmable RGB LEDs
  • LED backlit rings and icons
  • Momentary, toggle and multi-status
  • 2 blinking mode
  • Wide range of inserts
  • CAN-Bus system compatible
  • Vertical or horizontal mount
  • Status restore option
K keypads
The Push buttons can be:
MOMENTARY
  • The pushbutton status is ON when the pushbutton is pushed.
TOGGLE
  • The pushbutton status changes from ON to OFF every time the pushbutton is pushed.
MULTI-STATUS
  • The pushbutton value changes from 0 to a MAX value every time the pushbutton is pushed.
Our Featured Videos
RGB LED's
RGB LEDs are the best choice in low visibility conditions. Every pushbutton can be enlightened in 1 of 8 different colors, solid or blinking, according to the configuration defined by the user.
K keypads
Expansion Features
K Keypads can be connected to the AiM master devices such as dashes, dash loggers and PDMs.
They can be freely configurable as an expansion using the AiM software RaceStudio 3.
K keypads
Additional Controls
In addition to the primary functionality of the buttons, K6/K8/K15 buttons can be setup for managing the AiM display connected to the devices.
K keypads
Interchangeable Inserts
It is possible to choose among a wide range of inserts available; with 72 elements easily interchangeable, you'll have the possibility to create different configurations with the same K6/K8/K15 keypad based on any needs. View Inserts
K keypads
K Keypads | AiM EXPANSION
Connectable to the AiM master devices such as dashes, dash loggers and PDMs through the AiM Expansion CAN Bus (go the the section).
K keypads
K Keypads OPEN | OPEN VERSION
Freely configurable through USB, using the AiM software RaceStudio 3, they can be connected through CAN to every external device (go to the section).
K keypads
K6/K8/K15
Compact, Fully customizable, water and dust proof The K6, K8 and K15 are compact keypads based on CAN-Bus protocol.
  • 2 blinking mode
K keypads
MOMENTARY
TOGGLE
MULTI-STATUS
Our Featured Videos
RGB LED's
K keypads
Expansion Features
K Keypads can be connected to the AiM master devices such as dashes, dash loggers and PDMs. They can be freely configurable as an expansion using the AiM software RaceStudio 3.
K keypads
Additional Controls
K keypads
K keypads
K keypads
K keypads
Technical Specifications
  • K6 PushButtons: 6 programmable Keys
  • K8 PushButtons: 8 programmable Keys
  • K15 PushButtons: 15 programmable Keys
  • Backlight: RGB with dimming option
  • Connection: AiM CAN 5 pins Binder 712
  • K6 Dimensions: 97.4 x 71.4 x 24 mm
  • K8 Dimensions: 127.4 x 71.4 x 24 mm
  • K15 Dimensions: 157.4 x 71.4 x 24 mm
  • K6 Weight: 120g
  • K8 Weight: 150g
  • K15 Weight: 250g
  • Waterproof: IP67
Whats in The Box
Remote Button CAN Interface Pro Keypad
  • Your choice of Aim CAN Expansion Keypad
  • Your choice length for the Male 5 Pin CAN Cable
  • USB Cable For Aim EXP CAN Keypad
