Skip to product information
1 of 6
Honda CBR 600RR & 1000RR AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: HON-PP
£67.00
£67.00
Honda CBR 600RR & 1000RR Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for Honda bikes. Allowing easy installation to a Solo 2 DL and an EVO4S Data Logger. With a 7-pin 712 male binder connection.
Honda plug & play cable 7 pin - 712 male binder connection
Honda Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Honda bikes. This plug & play cable can be used for the Solo 2 DL and the EVO4S Data Logger.
CBR 600RR - 2003-2019 CBR 600RR HRC with D11 marked ECU - 2013-2015
CBR 1000RR - 2004-2016 CBR 1000RR HRC - 2014-2016
Example data protocols
The AiM ECU plug & play cable has been specifically designed for the Honda bikes. This plug & play cable can be used for the Solo 2 DL and the EVO4S Data Logger. The cable is an easy fitment to your bike and allows ECU data to be logged.  Please Note: If you are unsure this ECU cable will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.
Example data protocols sampled include RPM, Active gear, Vehicle speed, Front wheel speed, Rear wheel speed warning led, Engine coolant temperature, Brake pressure, Throttle position, Speed, ABS intervention, ALC intervention, Low fuel level, Traction control, Oil pressure, Map menu and many more. Refer to the technical sheet in the Downloads Tab for an extensive protocol list. Please Note: For these models/years Aim recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls.
  • Below is a pinout drawing for the Honda Solo 2 DL & EVO4S plug & play connection cable
  • Honda CBR 600RR, 1000RR Plug & Play connection cable
