    Grey 35 Pin AMP PDM Plug Connector Housing Socket - AimShop.com
    P-AMP-35-G
    In stock, ready to ship
    £15.00
    £15.00
    The 35 pin AMP plug is a brilliant and rugged connector housing. They boast high reliability under high temperatures and even feature an IP67 rating.
    35 pin AMP connector Rugged & highly reliable
    The 35 pin AMP plug is a brilliant and rugged connector housing. They boast high reliability under high temperatures and even feature an IP67 rating. The connector has a 2-piece contact hold design with secondary locking to prevent the contact from getting tore out under harsh conditions. These connectors accept a wire size of 0.5 to 1.25mm².
    Features and Benefits:
    • Rugged and highly reliable design
    • IP67 rating to protect against the harshest of conditions
    • Housed in a strong plastic
    • 2-piece contact hold
    • Integrated latch for mating
    • Operating temperatures of -40°C to +125°C
    • Number of contacts: 35
    • Type: Automotive connector housing
    • Gender: Male
    • Number of rows: 3
    • Current Rating: 17A
    • Mounting Type: Cable Mount
    • Colour: Black
    • Termination Method: Crimp
    • Height: 34.6mm
    • Width: 63.4mm
    • Depth: 33.6mm
    • Minimum Operating Temperature: -40°C
    • Maximum Operating Temperature: +125°C
    • Housing Material: PBT
    • Waterproof: IP6K9K
    • 1 x 35 Pin AMP Plug Connector
