Ducati Panigale 899, 959, 1199, 1199R, 1299, V4, V2 AiM Solo 2 DL Motorcycle Cable & Bracket
SKU: DUC-PP-DUC-1-B
- £125.00
- £125.00
The AiM Ducati Panigale motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.
Ducati Panigale cable & bracket | 7 pin - 712 male binder connection |
Ducati Panigale Solo 2 DL Cable & Bracket
The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.
The AiM Ducati Panigale bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
The plug & play cable currently fits the following Ducati Panigale bike models:
899 Panigale - 2013-2015 | 959 Panigale - From 2016 |
1199 Panigale - 2012-2014 | 1199R Panigale - 2015-2017 |
1299 Panigale - 2015-2019 | Panigale V4 - From 2018 |
Panigale V2 - From 2020 |
Example data protocols
- Specifically designed Ducati Panigale Plug & play cable and bracket for the Solo 2 DL
- Below is the pinout drawing for the Ducati Panigale plug & play connection cable.
- Ducati Panigale plug & play connection cable
- 1 bracket
- 1 washer
- 1 rubber dowel
The AiM Ducati Panigale motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.The AiM Ducati Panigale bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
The plug & play cable currently fits the following Ducati Panigale bike models:899 Panigale - 2013-2015 | 959 Panigale - From 2016 |
- 1 bracket
- 1 washer
- 1 rubber dowel
