    Auto Marine Superseal Plug with Seal & Pins Female & Male
    P-SS
    In stock, ready to ship
    £1.25
    £1.25
    Auto Marine's Super Seal Connectors are a range of compact, high-quality connectors with a water-resistant joint.
    Male or Female plug available Pins and seals
    Water-resistant joint Suits cables with 0.5mm to 1.5mm cross-section
    Auto Marine's Super Seal Connectors are a range of compact, high-quality connectors with a water-resistant joint. Suitable for cables with a cross-section area of 0.5mm to 1.5mm (approx 20 amps max), they are ideal for applications that require a sure-fitting, weatherproof connector.
    Available in male and female options to allow multiple connectors of the same side to be applied (e.g. various types of ends to plug onto a battery charger).
    Available in 1, 2, 3, 4, 5, and 6-way, Male and Female options
    • Plug housing for receptacle contacts, cap housings and tab contact varients
    • Silicone rubber seals
    • Suitable for powertrain, security and body & chassis systems
    • Male & Female available
    • 1, 2, 3, 4, 5 ,6 Pin available
    • Auto Marine Super Seal Plug with pin and seals
