    Bosch LSU 4.9 Probe - AimShop.com
    LCU-RS
    Bosch LSU 4.9 Probe
    In stock, ready to ship
    £125.00
    Bosch LSU 4.9 Probe
    £125.00
    Bosch LSU 4.9 Probe
    Bosch LSU 4.9 Probe
    The wideband lambda sensor LSU 4.9 is a planar ZrO2 dual cell limiting current sensor with an integrated heater. Its monotonic output signal in the range of lambda 0.65 to air makes the LSU 4.9 capable of being used as a universal sensor for lambda one measurement and other lambda ranges. The connector module contains a trimming resistor, which defines the characteristic of the sensor.
    Installation
    Bosch LSU 4.9 Probe
    • Application: Lambda 0.65
    • Hexagon temperature: <600°C
    • Thread: M18 x 1.5
    • Weight: 120g
    Bosch LSU 4.9 Probe
    • Bosch LSU 4.9 Probe
    Technical sheet Race Studio 3
