BMW S1000RR & S1000RR HP4 AiM Solo 2 DL Plug & Play Cable
SKU: BMW-PP
- £67.00
- £67.00
The AiM ECU plug & play cable has been specifically designed for BMW bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
BMW plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL |
BMW Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the BMW bike. This plug & play cable can be used for the Solo 2 DL.
The plug & play cable currently fits the following BMW bike models:
![Aim Cobra ECU For Honda Motocross Bikes](https://cdn.shopify.com/s/files/1/0214/9392/files/BMW_Bike_2.png?v=1620402151)
S1000RR - 2009-2014 | S1000RR - From 2015 |
S1000RR HP4 - 2013-2014 |
Example data protocols
- Below is a pinout drawing for the BMW Solo 2 DL plug & play connection cable
- BMW S1000RR, S1000RR HP4 Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for BMW bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the BMW bike. This plug & play cable can be used for the Solo 2 DL.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following BMW bike models:![Aim Cobra ECU For Honda Motocross Bikes](https://cdn.shopify.com/s/files/1/0214/9392/files/BMW_Bike_2.png?v=1620402151)
These are some of the items that can be added to your bike for incrementing performance and data. ![]() |
![BMW S1000RR & S1000RR HP4 AiM Solo 2 DL Plug & Play Cable - AimShop.com](http://www.aimshop.com/cdn/shop/products/BMWS1000RR_S1000RRHP4AiMSolo2DLPlug_PlayCablenew_1445x.png?v=1620811545)
![BMW S1000RR & S1000RR HP4 AiM Solo 2 DL Plug & Play Cable - AimShop.com](http://www.aimshop.com/cdn/shop/products/BMWS1000RR_HP4AiMSolo2DLPlug_PlayCable_1445x.png?v=1620811545)
![BMW S1000RR & S1000RR HP4 AiM Solo 2 DL Plug & Play Cable - AimShop.com](http://www.aimshop.com/cdn/shop/products/BMWS1000RR_HP4Solo2DLPlug_PlayCablewith7PinMale712Connector1_1445x.png?v=1620811545)
