AiM Yarara Yamaha ATV ECU Plug & Play
SKU: Y-ECU
- £480.00
- £480.00
AiM Yarara Yamaha ATV ECU Plug & Play Engine Control Unit
Yarara is the plug & play ECU developed by AiM for being installed on the Yamaha YFZ450R. Thanks to its high technology 32-bit core, it is a good help for improving the performances of your ATV, without sacrificing reliability and smoothness.
Yarara is specifically designed for:
Yamaha YFZ450R Model year 2021 and 2022
Yarara Key Features & Advanced Strategies
Injection main | Injector 2 percentage |
Injection user compensation | Injector 2 phase |
Injection main speed density | Injector opening transient correction |
Injection crank correction |
Injector closing transient correction |
Pre-injection | Ignition main |
Injection BAP correction | Ignition user compensation |
Injection EWT correction | Ignition BAP correction |
Inection IAT correction | Ignition EWT correction |
Injector 1 battery correction | Ignition IAT correction |
Injector 1 phase | Ignition opening transient correction |
Injector 2 battery correction | Ignition close transient correction |
High Technology 32-bit Core
Engine control requires precision. At 20,000 RPM the Yarara ECU guarantees the precision of 1/10 of the degree: this means an accuracy within 0.8 uses for turning the spark ON!
![](https://cdn.shopify.com/s/files/1/0214/9392/files/tick-icon.png?v=1616588820)
Tuner License :
This is the Tuner that is required to configure the unprogrammed Yarara ECU.
With this license, the tuner can create different maps, configurations and strategies. The tuner can then flash them directly onto the ECU or send them via email to allow the rider to download and install them in the ECU.
The Aim Handlebar Switch is the best way for changing the behaviour of your UTV; it features 2 pushbuttons, 10 LEDs and manages the following settings :
Below shows a functional diagram of products that can be added to the Yarara ECU:
AiM Yarara ECU Plug & Play Engine Control Unit
- Two 0-5V analogue inputs sampled @ 1,000 Hz each, could be alternatively used as a switch to ground
- Second injector driver for high impedance saturated injectors (12Ω)
- One low side driver (1 A)
- Two CAN Bus, one for calibration purposes, one for expansions - (AiM handlebar switch, dataloggers, dash etc
- Three JST JWPF waterproof auxiliary connector
- Power consumption 150 mA
- Connectors:
- n.1 JAE male 18 pin MX23A18NF1 Connector
- n.1 34 pin male Connector
- Body: PA6 + 30% glass fiber
- Dimensions: 141.5x84.3x26.9 mm
- Weight: 370g
- ECU Yarara Control Unit
Yarara is the plug & play ECU developed by AiM for being installed on the Yamaha YFZ450R. Thanks to its high technology 32-bit core, it is a good help for improving the performances of your ATV, without sacrificing reliability and smoothness.Yarara is specifically designed for:
![](https://cdn.shopify.com/s/files/1/0214/9392/products/YararaECUFront_Compressed_480x480.png?v=1657105171)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/AiM_Cobra_Motocross_Unprogrammed_ECU_Plug_Play_Engine_Control_Unit_UC_Tuner.png?v=1621948390)
Tuner License :
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Aim-Cobra-Handlebar-Switch.gif?v=1617277273)
![](https://i.gyazo.com/d71cf57c6095b7b4f9f0e662443c1ff9.png)
- Connectors:
- Weight: 370g
Video
![AiM Yarara Yamaha ATV ECU Plug & Play - AimShop.com](http://www.aimshop.com/cdn/shop/products/YararaECUFront_Compressed_1445x.png?v=1657105171)
![AiM Yarara Yamaha ATV ECU Plug & Play - AimShop.com](http://www.aimshop.com/cdn/shop/products/YararaECUFrontPerspectiveWithHarness_Compressed_1_1445x.png?v=1657179723)
![AiM Yarara Yamaha ATV ECU Plug & Play - AimShop.com](http://www.aimshop.com/cdn/shop/products/YararaECUFrontPerspective2WithHarness_Compressed_1445x.png?v=1657179723)
![AiM Yarara Yamaha ATV ECU Plug & Play - AimShop.com](http://www.aimshop.com/cdn/shop/products/YararaECUFrontPerspective2_Compressed_1445x.png?v=1657179723)
![AiM Yarara Yamaha ATV ECU Plug & Play - AimShop.com](http://www.aimshop.com/cdn/shop/products/YararaECUFrontPerspective_Compressed_1445x.png?v=1657179723)
![AiM Yarara Yamaha ATV ECU Plug & Play - AimShop.com](http://www.aimshop.com/cdn/shop/products/YararaECUSide_Compressed_1445x.png?v=1657179723)
![AiM Yarara Yamaha ATV ECU Plug & Play - AimShop.com](http://www.aimshop.com/cdn/shop/products/YararaECUTop_Compressed_1445x.png?v=1657179723)
![AiM Yarara Yamaha ATV ECU Plug & Play - AimShop.com](http://www.aimshop.com/cdn/shop/products/YararaECUBottom_Compressed_1445x.png?v=1657179723)
![AiM Yarara Yamaha ATV ECU Plug & Play - AimShop.com](http://www.aimshop.com/cdn/shop/products/YararaECUHarness_Compressed_1445x.png?v=1657275422)
