Skip to product information
1 of 5
AiM Tyre Temperature Sensor Bracket Kit
SKU: S-TT-BK
£155.00
£155.00
The AiM Tyre Temperature Sensor Bracket is a dedicated kit to ensure the secure mounting and installation of the sensors.
For use with the Tyre Temperature Sensor Kit Brackets for four sensors
The AiM Tyre Temperature Sensor Brackets are a dedicated kit for the secure mounting and installation of the four sensors which will use it.
The kit includes four brackets and fittings, enabling the optimum mounting of the sensors in the correct place to get accurate temperature readings from all four tyres.
Connection
When installing the Tyre Temperature Sensor brackets, ensure that the sensors are installed away from strong heat sources, like the exhaust gas pipe and keep away from electromagnetic interferences.
Please refer to the technical sheet in the Downloads Tab for all information, including images, diagrams on how to fit the sensors to the brackets and your Kart.
Optional Extras
Spare Tyre Temperature Sensors are available should you wish to carry spares. 712-719 4 pin patch leads are also available to purchase if reserves are required.
Available in the Accessories Tab.
Above shows the Tyre Temperature Sensor Kit, which requires the bracket to fit the sensors. Available in the Accessories Tab.
Above is an example of devices that you can add to your system to enhance your racing performance.
Connection
Optional Extras
  • Front Right, Front Left, Rear Right, Rear Left Brackets
  • Screws M6 & M5
  • Washers
  • Please refer to the user guide on how to install the the tyre temperature brackets
  • Front Left, Front Right, Rear Left, Rear Right Brackets
  • M6 x 25mm screws
  • M3 x 10mm screws
  • M5 x 20mm screws
  • M6 nuts
  • M5 nuts
  • Washers
