Skip to product information
1 of 1
AiM Strada 1.2 IVA Vehicle Integration Loom MXS, MXP, MXG
SKU: MX-S-VIL-MC
£195.00
£195.00
The AiM pre-wired Strada 1.2 23 pins IVA Integration loom is a dedicated wiring loom to integrate with our IVA dash displays, offering a simple installation to your vehicle electrics.
23 pin pre-wired loom Additional speed sensor
Fits MX Series Perfect for kit car builders
The AiM Strada 1.2 23 pin IVA loom with a wheel speed sensor is a dedicated wiring loom made to integrate with the IVA dash displays. The loom will offer a simple installation for your vehicle electrics.
Allowing the perfect solution for kit car builders, the system will allow you to monitor:
All ECU information and Odometer
Oil Temperature
Engine Temperature
Fuel Levels
Side Lights
Hazards
Front Fog
Rear Fog
Parking Brake
Main Beam
Dipped Beam
LH Indicator
RH Indicator
A fuel level sender can work with the AiM Channel Expansion unit with a suitable patch lead.
The IVA loom has a pull-up resistor incorporated, which is unnecessary with the fuel level sender and can cause inconsistent readings.
  • Strada IVA 23 pin Integration Loom
  • Wheel Speed Sensor
  • Wire Code:
  • Channel 1 - Yellow - Fuel Level
  • Channel 2 - Green - Engine Temperature
  • Channel 3 - Violet - Oil Pressure
  • Channel 4 - Orange & Brown - RH Indicator & LH Indcator
  • Channel 5 - Blue - Main Beam
  • Channel 6 - White - Dipped Beam
  • Channel 7 - Grey - Side Lights
  • Channel 8 - Pink - Rear Fog Light
  • Black - RPM
  • Blue-Brown-Black - Wheel Speed Sensor
  • 1 X 23 pin IVA Strada 1.2 Integration Loom with Wheel Speed Sensor
Oil Temperature
Engine Temperature
Fuel Levels
Side Lights
Hazards
Front Fog
Rear Fog
Parking Brake
Main Beam
Dipped Beam
LH Indicator
RH Indicator
  • Wire Code:
  • Black - RPM
