Skip to product information
1 of 2
AiM SmartyCam HD 2.1 & SmartyCam 3 U Bolt Mount Offroad
SKU: SM-UB-MX-X90KSTP00
£60.00
£60.00
The SmartyCam can be installed using the U bolt mount. It is suitable for SmartyCam HD 2.1 & SmartyCam 3.
Secure mounting for SmartyCam Ball & socket system
Suitable for 0.5 to 1.2" For SmartyCam HD 2.1  & SmartyCam 3
The AiM SmartyCam U Bolt mount allows you to mount your SmartyCam to your car/motorcycle.
The mount has been designed to mount to a roll bar, railings, or tubes that have a diameter of between 0.5 to 1.5 inches. The U bolt clamp has a unique ball and socket system which has been designed to cope with the rigours of motorsport.
The mount is adjustable, once you have the camera in the optimal position to capture the best footage you just need to tighten the leaver to secure the camera in place.
U Bolt Mount
Securely attaches to any roll bar, railing or tube with a diameter of 0.5 to 1.2 inches.
  • For use with SmartyCam HD 2.1 & SmartyCam 3
  • 1 U-Bolt and straps
  • 160mm single ball arm
  • 1 Ball head
  • 1 washer diameter 17.7mm, thickness 1.5mm, hole 6mm
Technical sheet Race Studio 3
U Bolt Mount
  • 1 Ball head
