Skip to product information
1 of 2
AiM SmartyCam 2.1 HD & SmartyCam 3 Roll Cage Mount Motorcycle
SKU: SM-VB-X90KSSMC0
£60.00
£60.00
The SmartyCam HD can be installed using the HD roll cage mount. It is suitable for SmartyCam HD 2.1 & SmartyCam 3.
Secure mounting for SmartyCam Ball & socket system
Suitable for 0.5 to 1.2" For SmartyCam HD 2.1 & SmartyCam 3
The AiM SmartyCam roll cage mount allows you to mount your SmartyCam to your car/motorcycle.
The SmartyCam roll cage mount has been designed to securely mount the AiM SmartyCam camera.
The V bracket adjusts by using the ball and socket type system for optimising positioning and simply clamps to roll bars of a wide range of diameters.
Please Note: This bracket is only suitable for the SmartyCam HD 2.1 & SmartyCam 3.
Roll Cage Mount
Securely clamps to a roll bar of a wide range of diameters.
  • For use with SmartyCam HD 2.1 & SmartyCam 3
  • Arm height 160mm ( 6.30 inches)
  • 1 Handlebar bracket and straps
  • 160mm single ball arm
  • 1 ball head
  • 1 washer diameter 17.7mm, thickness 1.5mm, hole 6mm
Technical sheet Race Studio 3
Roll Cage Mount
  • 1 ball head
