Skip to product information
1 of 4
AiM MXS 1.3 Strada BMW IVA 5" TFT Display Plug & Play Kit
SKU: MXS-S-BMW-KIT
£1,200.00
£1,200.00
AiM MXS 1.3 Strada IVA Compliant 5" Dash Display Plug & Play Kit
The MXS 1.3 Strada IVA compliant digital dash display is a complete road legal display solution for OEM kit car and race builders.
5" compact TFT display 6 alarm RGB LEDs
CAN output Configure data
Connecting the MXS 1.3 Strada dash to your ECU is simple. You can sample and display dozens of channels straight from the vehicle ECU. This is usually the quickest and easiest setup, needing only 2 cable connections to the ECU instead of multiple connections to analogue sensors.
The 23 pin loom has pre-configured connections for all the main relevant electrical items in your vehicle such as oil, temperature, fuel level, sidelights, hazards, front and rear fog, handbrake, main beam, dipped beam and left and right-hand indicator. A speed sensor is also included in the kit to connect to this additional loom.
Digital Outputs
With CAN Output you can send messages directly to an existing  CAN network to improve the range of vehicle control possibilities.
Pre-configured Pages
Flexible Shift Light & Alarms
Camera Inputs
With Race Studio 3 you can also analyse all data recorded by MXS 1.3 Strada and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.
  • Display : 5" TFT
  • CAN Connections: 2
  • Second CAN: Yes
  • Body: Anodized Aluminium
  • Pushbuttons: Metallic
  • Power Consumption: 400 mA
  • Dimensions: 169.4 x 4 x 97 x 23mm
  • Weight: 480g
  • MXS 1.3 Strada
  • 23 pin IVA Loom
  • Wheel Speed Sensor
Digital Outputs
Camera Inputs
  • Display : 5" TFT
  • Second CAN: Yes
  • Weight: 480g
  • MXS 1.3 Strada
  • 23 pin IVA Loom
