Skip to product information
1 of 18
Aim MXPS Suzuki GSX-R1000 (2017-2022) Plug & Play Dash Logger
SKU: MXPS
£995.00
£995.00
Elevate Your Suzuki Dash
The Aim MXPS is a state-of-the-art plug & play dash logger designed specifically for the Suzuki GSX-R1000 and GSX-R1000R models from 2017 to 2022. This advanced system seamlessly integrates with your Suzuki dash, providing comprehensive data logging and a customisable display to enhance your riding experience.
2 CAN connections 9 alarm LEDs
4 GB internal memory 1,100 Lumen display
10 shift lights LEDs IP65 waterproof rated
6" TFT high contrast display Anodised aluminium body
JAE & Binder connectors Yoshimura harness compatible
Why Upgrade Your Suzuki Dash With The MXPS?
The Aim MXPS offers a comprehensive upgrade to your Suzuki dash, combining modern aesthetics with advanced data logging capabilities. Whether you're on the track or the road, the MXPS provides the information you need to enhance your riding experience.
Please Note: The MXPS dash can be programmed with your current mileage. Please state your required mileage in miles or kilometres in the notes section on your order.
MXPS Suzuki Dash
Customisable Display Views & Integrated LEDs
The MXPS dash has 2 types of displays: road or track and even analogue or digital themes, with light and dark modes for each to suit your preferences. There is also a wide range of icons available on the display, allowing you to easily see important information whilst you’re driving: fault indicator, oil pressure issues, water temperature, servicing indicator, fuel level etc.
The MXPS features 10 shift light LEDs, as well as 9 alarm LEDs showing high beam on, engine problems, traction control active/error, ABS active/error and configurable LEDs to name some of the alarm features.
Analogue Vs Digital MXPS Suzuki Dash
Connections & Expansions
The MXPS plug & play dash logger is compatible with various expansions and modules to enhance performance and expand on data collection to get the best out of your GSX-R 1000. Compatible expansions include:
  • Lambda Controller: Monitor your air-fuel ratio for optimal engine performance with the EXP connection.
  • USB or Wi-Fi connection: Enables you to download data and configure your MXPS.
  • SDS+Analogue Connection: Gives you the possibility to read 28 ECU extra channels and 4 user-defined analogue inputs.
  • SmartyCam HD Cameras: Integrate video with data overlay for comprehensive analysis. Analogue camera input also allows you to swap your display into a mirror camera through push button command or event management.
Back of MXPS Suzuki Dash
MXPS Suzuki Dash Connection Example
User-Friendly Experience
The MXPS benefits from a user-friendly menu, ensuring that navigation and configuration of the dash is simple and clear. Setting up your MXPS is just a matter of riding style: choose what perfectly fits your road/track needs. The complete menu allows you to easily modify every parameter of your bike: ECU maps, traction control, anti-wheeling, ABS and so on.
MXPS Suzuki Dash Screen Examples
Advanced Data Acquisition
The MXPS transforms your Suzuki dash into a powerful data-logging system, capturing real time performance metrics from your bike’s ECU, GPS module and additional sensors and modules that have been added.
Equipped with a GPS09 Module, the MXPS provides precise GPS speed, lap timing and track mapping, automatically detecting circuits from its comprehensive database. With the MXPS racing kit, you can read 28 ECU extra channels and connect up to 4 sensors to gain insights into RPM, throttle position, temperature and more.
Once data is collected, it can be reviewed on the dash or analysed in-depth using Race Studio 3, which visualises performance insights through graphs, histograms and tables. Whether you're fine-tuning your setup for the track or aiming for personal bests, the MXPS dash logger provides everything you need to optimise your Suzuki’s performance and take your riding to the next level.
MXPS Racing Kit MXPS Suzuki Dash Installation Suzuki FIM Endurance World Championship Bike
Please Note: The MXPS dash can be programmed with your current mileage. Please state your required mileage in miles or kilometres in the notes section on your order. MXPS Suzuki Dash
The MXPS features 10 shift light LEDs, as well as 9 alarm LEDs showing high beam on, engine problems, traction control active/error, ABS active/error and configurable LEDs to name some of the alarm features. Analogue Vs Digital MXPS Suzuki Dash
The MXPS benefits from a user-friendly menu, ensuring that navigation and configuration of the dash is simple and clear. Setting up your MXPS is just a matter of riding style: choose what perfectly fits your road/track needs. The complete menu allows you to easily modify every parameter of your bike: ECU maps, traction control, anti-wheeling, ABS and so on. MXPS Suzuki Dash Screen Examples
Aim MXPS Suzuki GSX-R1000/R (2017-2022)
  • Display: 6" TFT
  • Resolution: 800x480 pixels
  • Contrast: 600:1
  • Ambient Light Sensor: Yes
  • Alarm LEDs: 9
  • Shift Light LEDs: 10
  • CAN connections: 2
  • ECU Connection: Yes
  • External Modules: GPS Module, Channel Expansion, Lambda Controller, TC Hub, SmartyCam HD
  • Wi-fi Connection: Yes
  • Internal Memory: 4GB
  • Body: Anodised Aluminium
  • Connectors: 1 32 pins JAE main connector + 4 Binder 712 female connectors
  • Weight: 620g
  • Power Consumption: 400 mA
What's In The Box
MXPS Plug & Play Dash Logger for Suzuki GSX-R 1000
  • MXPS Plug & Play Dash
  • Fixing/Installation Kit
  • GPS09 Module
